A switch module component, creating and initializing system I/O communication conduits between management modules and I/O blades, has detected an invalid range for one of the API's parameters. An internal application invocation may have settings that are beyond the allowable range.
No remedy is available.
Error
System I/O conduit initialzation for %textType% has detected %reason% for: slot # %slotNo%; pipe # %pipeNum%; first conduit # %firstCond%; total # of conduits %totalCond%.
| Name | Type |
| slotNo | uInt |
| pipeNum | uInt |
| firstCond | uInt |
| totalCond | uInt |
| textType | String |
| reason | String |
